Normal Topic Spurious tabs inserted by XML Viewer (Read 4259 times)
sreuss
Jul 6th, 2010 at 11:54am
When adding a comment to a node that already contains text, the text gets corrupted by the addition of extra tab characters each time the XML file is saved.  More saves means more tabs....
Is there a known work-around for this?
Thanks in advance,
Steve
Re: Spurious tabs inserted by XML Viewer
Reply #1 - Jul 6th, 2010 at 12:52pm
Can you e-mail to meppy@minsdfusion.eu the XML file, which when opened and saved produces the extra tabs?
