Normal Topic Is MindFusion.Scheduling good for my project? (Read 2463 times)
Firmware
Jul 7th, 2010 at 6:29am
Hi all,
I have to make a planning application for 3 machines. Where employees can assign tasks to the machines witch will contain all machineproperties and a start and end hour. And when the planning is ok for that one day it should be possible to store/save it in a database.
Would Scheduling come handy in my case?
Thank you!
Re: Is MindFusion.Scheduling good for my project?
Reply #1 - Jul 7th, 2010 at 7:34am
Scheduling appointments (tasks in your case) over resources (machines in your case) is one of the main purposes of MindFusion.Scheduling for WPF.
However, a direct database serialization is not supported so you will need to manually implement it by either storing individual properties of the tasks to database fields or by serializing the tasks to XML strings and then storing the entire strings to the database.
