Normal Topic Anchor points and link bebhaviour (Read 1433 times)
Hunter
Jul 15th, 2010 at 5:30am
Hello, Stoyo!
I have the ShapeNode-based class for describing behaviour and properties of my nodes. So I have also the
public override void DrawHandles(DrawingContext graphics, HandlesVisualStyle style)
method and I have the method for HitTestAdjustment Event. But the link starts drawing only when mouse cursor is over the node area. The anchor point is a circle with diametr 6 and center which located on the node visual border. How can I force the link to draw when mouse is over the cirsle area which indicates the anchor point?
Re: Anchor points and link bebhaviour
Reply #1 - Jul 15th, 2010 at 7:25am
Try overriding the StartDraw method of a custom behavior class. Return a new InteractionState(new DiagramLink(), Action.Create) from it if the mouse pointer is inside the anchor area.
Hunter
Reply #2 - Jul 15th, 2010 at 8:32pm
Ok! I'll try. If I will have the problems I write to you. Thanks.
