Normal Topic How can i test the Bpmn shapes from my Code (Read 6456 times)
chiru29
Jul 16th, 2010 at 6:59am
We have purchased 4.0.4.5 version of Mindfusion.flowchartX Proffesional.
We are planning to upgrade to 4.3.1, as we need to use Bpmn shapes.
Can i test them by downloading the Evaluation version?
i didn't found any dll with name Mindfusion.FlowchatX.dll in the downloaded package.
How can i test the Bpmn shapes from my Code, with this evaluation version?
Regards
Chiru
Re: How can i test the Bpmn shapes from my Code
Reply #1 - Jul 16th, 2010 at 7:10am
Are you using our ActiveX or .NET flowchart control?
chiru29
Reply #2 - Jul 16th, 2010 at 7:12am
I am using .Net flowchart control
Thanks & Regards
Chiru
Reply #3 - Jul 16th, 2010 at 7:18am
Then you will need this version -
There's no Mindfusion.FlowchatX.dll anymore though, and you will have to update your code to work with version 5.x - there are many changes since V4.0.4.
chiru29
Reply #4 - Jul 16th, 2010 at 7:23am
Thanks Stoyo.
Is the following is Proffesional version?
Chiru
Reply #5 - Jul 16th, 2010 at 7:51am
Yes, it is.
chiru29
Reply #6 - Jul 16th, 2010 at 7:57am
Is there any documentation containing the changes to all the classes from FlowChartX to version 5.x ?
It seems there many changes in the classes also.
Chiru
Reply #7 - Jul 16th, 2010 at 8:27am
It's here.
chiru29
Reply #8 - Jul 19th, 2010 at 10:14am
Thanks Stoyo. It's really helpful.
But, i found some of the members of Flowchart class like ArrowColor, BoxFrameColor, Visible, TableFrameColor not exists in Diagram/DiagramView classes. Are they removed?
Can you please advice, how to use these properties?
Chiru
Reply #9 - Jul 19th, 2010 at 11:15am
Hi Chiru,
ArrowColor, BoxFrameColor and TableFrameColor correspond to the Color component of the LinkPen, ShapePen and TablePen objects. The Visible property is derived from Control and so it's member of DiagramView now.
