Normal Topic Divide Diagram region(area) in multiple region (Read 1971 times)
rajesh_patil74
Jul 21st, 2010 at 7:25am
Hi Stoyo
Is it possible to divide the diagram area region in multiple regions so that whenever I apply the layout nodes will be shown in specific region alloted.
For eq. In following image
http://public.bay.livefilestore.com/y1pFgWZcWbjbI_v-3KiYKHMQUv8hAuTLvEMeAUHoHh8E...
the region needs to be divided in 2 rows and second row should be divided in 2 columns ( OR divide the diagram region in 2 rows and 2 columns) and later on show the diagram nodes in specific region alloted.
Regards
Rajesh
Re: Divide Diagram region(area) in multiple region
Reply #1 - Jul 21st, 2010 at 7:40am
Hi Rajesh,
Only the force-directed algorithms support that through their LayoutArea property.
The area used by other layout classes depends on properties such as NodeDistance and LevelDistance. For them you can only specify the top-left position of the arranged graph through layout.Margins.
rajesh_patil74
Reply #2 - Jul 21st, 2010 at 7:42am
Hi Stoyo
I didn't get what you mean by force-directed algorithms.
Can you provide me some example for same.
-Rajesh
Reply #3 - Jul 21st, 2010 at 7:48am
Check SpringLayout and AnnealLayout.
