Normal Topic How can we access DiagramView from a DiagramNode (Read 3423 times)
chiru29
Jul 22nd, 2010 at 9:04am
If i have a DiagramNode in a diagram, i am able to access the diagram by DiagramNode.Parent property.
Same way, can i access DiagramView from a diagram node?
Chiru
Re: How can we access DiagramView from a DiagramNo
Reply #1 - Jul 22nd, 2010 at 10:29am
Neither a Diagram nor its nodes know what DiagramViews they are displayed in. There's a way to access the view from a DiagramNode.Draw override - use the TargetView property of the options argument. If you are using multiple views and need to access them in other situations, you could build a Dictionary<Diagram, List<DiagramView>> map that lets you find them.
chiru29
Reply #2 - Jul 22nd, 2010 at 11:52am
Thanks Stoyan.
If you can give me an example of this, that whould be very helpful.
Chiru
Reply #3 - Jul 22nd, 2010 at 12:23pm
private Dictionary<Diagram, List<DiagramView>> viewMap =
	new Dictionary<Diagram, List<DiagramView>>();
void AddView(Diagram d, DiagramView v)
	if (!viewMap.ContainsKey(d))
		viewMap[d] = new List<DiagramView>();
	viewMap[d].Add(v);
List<DiagramView> GetViews(DiagramNode node)
	return viewMap[node.Parent];
Call AddView each time you create a new view for a diagram, and GetViews when you need to find out the views that display some node.
chiru29
Reply #4 - Jul 23rd, 2010 at 11:07am
Thanks. It is very helpful.
Regards
Chiru
