Normal Topic PDF Export with Custom Nodes (Read 1429 times)
ChrisGC
Jul 22nd, 2010 at 5:58pm
Hi again Stoyo,
The next step in my project is to export to PDF. I have no issue with taking the approach detailed in:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=125248...
But I note your comment on custom nodes:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=125836...
I have custom nodes similar to those in the OrgChart example (using a ControlTemplate: generic.xaml)... Therefore before I go too far down this route, am I going to run into the aforementioned issues? If so any pointers?
Chris
Re: PDF Export with Custom Nodes
Reply #1 - Jul 22nd, 2010 at 6:32pm
Hi Chris,
You will have to implement the custom node class on the server side too, and call RegisterItemClass to be able to load the diagram XML.
You will also have to implement the node.Draw method using GDI+ code, or from what I have seen in your screenshots you might easily replace the custom nodes with TableNodes to reuse their rendering. E.g. the table would have 2 columns x 8 rows, and you can copy the custom data to the table cells and set ColumnSpan = 2 for the image cell.
Implementing node.Draw won't be much more work than transferring the custom data to a TableNode though.
