Normal Topic loadFrom , saveTo for Streaming . (Read 2014 times)
gamjaradio
Aug 5th, 2010 at 2:43am
I'm in a project using socket communication.
so need to send the Stream for my picture of Diagram.
but, I cant know how to save and Load.
I know there is the method , saveTo, loadFrom.
but need to have an example.
please give me the advice of saveTo(OutputStream),
and loadFrom(InputStream)
Re: loadFrom , saveTo for Streaming .
Reply #1 - Aug 5th, 2010 at 7:40am
This save and loads from a memory stream:
ByteArrayOutputStream out = new ByteArrayOutputStream();
try
	diagram.saveTo(out);
catch (IOException e)
	JOptionPane.showMessageDialog(this, e.getMessage());
	return;
ByteArrayInputStream in = new ByteArrayInputStream(out.toByteArray());
try
	diagram.loadFrom(in);
	out.close();
	in.close();
	return;
I don't know if these methods will work with network streams. If they don't, you can use the saveToString and loadFromString methods instead, and send the string across the network.
