Normal Topic Enable AutoRoute without Recalcing the Route (Read 1267 times)
Nedor
Aug 6th, 2010 at 8:35am
If I enable the autoroute feature with
Link.AutoRoute = true;
the engine trys to AutoRoute this link. But i have to Add much Nodes/Links in one operation. In this case the AutoRoute algorithm slows down the whole program a lot. Is there any way to enable the AutoRoute Feature, but don't calculate the best route currently, so the best Route ist Calculated the next time the link (or one node which is connected to the link) will be changed.
Re: Enable AutoRoute without Recalcing the Route
Reply #1 - Aug 6th, 2010 at 8:45am
Use the Suspend and Resume methods of diagram.LinkRouter.
Nedor
Reply #2 - Aug 6th, 2010 at 10:15am
That was really what i needed. I have overlooked this function in the api.
Much thanks to you.
