We are getting unhandled exception in our application when we delete some nodes and in the same time trying to select some other nodes.
Unhandled Exception in Application
DateTime: 8/6/2010 2:16:55 PM
Exception: Object reference not set to an instance of an object.
Stack Trace: at MindFusion.Diagramming.Wpf.InteractionState.IsAllowed(Point point)
at MindFusion.Diagramming.Wpf.Behaviors.BehaviorBase.OnMouseUp(Point mousePosition, MouseButton mouseButton)
at MindFusion.Diagramming.Wpf.Diagram.x355258a28dc3da25(MouseButtonEventArgs xfbf34718e704c6bc, Point xb30c565aa19aece6)
at MindFusion.Diagramming.Wpf.Diagram.OnPreviewMouseUp(MouseButtonEventArgs e)
at System.Windows.UIElement.OnPreviewMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
Exception Source: MindFusion.Diagramming.Wpf
InnerException:
Scenario is like this,
1. We have opened two instances of our application.
2. Application is synchronized through the event, change in one instance reflects in another instance.
3. We have Tile both the window and select some node in first instance.
4. Delete selected node of first instance and at the same time try to select those nodes in second instance.
After step 4, we are getting above mentioned exception.
Please let us know your suggestion as soon as possible. It is a critical issue for our application.
Anshul
