Normal Topic After Routing Event (Read 1082 times)
Nedor
After Routing Event
Aug 6th, 2010 at 12:59pm
Is there any event which is called after the AutoRouting is done?
I need to know the controlpoints of the link. I tried the LinkRouted event. But it seems, that its called before the routing was done.
On useractions i can update it easily, but if the user moves a node around, and a reroute is triggered, I have no chance to get the new controlpoints.
Re: After Routing Event
Reply #1 - Aug 6th, 2010 at 1:45pm
It seems that happens when routing is suspended, otherwise LinkRouted is raised after the points are set from what I can see. Are you calling Resume for each Suspend? Or do you need to know what new points are set after auto-routing is resumed?
