Normal Topic JavaScript Error in resourceview (Read 4291 times)
martmuller
Aug 9th, 2010 at 1:05pm
We are running into the following js error when showing the (resource) calendar for the first time:
[code]Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E)
Timestamp: Mon, 9 Aug 2010 12:58:01 UTC
Message: Unhandled Error in Silverlight Application [ArgumentOutOfRange_Index]
Arguments:
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=4.0.50524.0&File=mscorlib.dll&Key=ArgumentOutOfRange_Index
Parameter name: index at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at MindFusion.Scheduling.Silverlight.x9dda3d4982098ce9.xaa6601c08b75ee70()
at MindFusion.Scheduling.Silverlight.x9dda3d4982098ce9.<>c__DisplayClass6.<Render>b__5(Object s, SizeChangedEventArgs e)
at System.Windows.FrameworkElement.OnSizeChanged(Object sender, SizeChangedEventArgs e)
at MS.Internal.JoltHelper.RaiseEvent(IntPtr target, UInt32 eventId, IntPtr coreEventArgs, UInt32 eventArgsTypeIndex)
Line: 1
Char: 1
Code: 0
URI: http://vdevmart-w2k3/default.aspx
[/code]
I cannot resolve the error in debug mode or any try/catch. Everything runs normally so there is nothing broken I think and after reloading the resources in the calendar, the js error does not popup anymore.
Do you have any clue if this is a bug or where I should look at resolving this error?
Mart
Re: JavaScript Error in resourceview
Reply #1 - Aug 9th, 2010 at 1:48pm
It looks like an error we have fixed recently. Can you try it out with the assemblies I have sent you in a private message and let me know if the problem has been solved?
martmuller
Reply #2 - Aug 12th, 2010 at 9:25am
Yes the problem has been resolved, thanks a lot! Is this a trail version or a licensed version you sent me?
Mart
Reply #3 - Aug 12th, 2010 at 9:47am
It should be a licensed one. On a side note, a release of version 2.2 of the component, which includes undo/redo functionality, is imminent and you will be able to download it form the client's area once it is out.
