Normal Topic Change the behavior of the overview (Read 1046 times)
yrauma
Aug 9th, 2010 at 11:52pm
Hello Stoyan,
I would like to modify the behavior of the overview object.
Currently, we used it to navigate in the diagram and it works fine.
The rectangle in the overview that represents the part of the diagram that the user can see is the part I would like to change.
In the best case I would love to be able to draw this rectangle, the same way as a selection rectangle. the user clic, hold + drag and draw the selection rectangle which will then, after a mouse release, update the diagramView.
But as the Viewport property of the overview is internal, I cannot override it in any way in an extended class...
So im kinda out of idea.
Is it possible ? can you help me ?
Amaury
Re: Change the behavior of the overview
Reply #1 - Aug 10th, 2010 at 8:32am
Hi Amaury,
You could do that by directly setting the DiagramView's scroll and zoom values upon MouseUp. Rendering the selection rectangle can be done from an OnPaint override,  but while drawing with the mouse you will see both the standard tracker rectangle and the currently drawn rectangle. We'll try to add an easier way to override this for the next release.
