Normal Topic Binding the Nodes property (Read 2530 times)
IainS
Aug 11th, 2010 at 11:16am
I'm looking at WpfDiagram and I'm trying to populate the Nodes on the diagram using databinding (e.g., I'd like to bind the Nodes property to an ObservableCollection of objects and when the collection changes, have the diagram update accordingly).
I haven't found a way to do this, and I can't see this done in any of the supplied samples.
Is it possible to achieve what I'm trying to do?
Re: Binding the Nodes property
Reply #1 - Aug 11th, 2010 at 11:41am
WpfDiagram does not support databinding yet.
Amosius
Reply #2 - Sep 2nd, 2010 at 8:40am
Hi Stoyan,
I have the following class (example):
[code]
class Task : ShapeNode, INotifyPropertyChanged
string _taskname;
public event PropertyChangedEventHandler PropertyChanged;
public Task()
public string TaskName
get { return _taskname; }
set
_taskname = value;
OnPropertyChanged("taskname");
protected void OnPropertyChanged(string property)
if (PropertyChanged != null)
PropertyChanged(this, new PropertyChangedEventArgs(property));
[/code]
[code]
XAML:
<TextBox Name="Name" Text="{Binding Source=Task, Path=TaskName, UpdateSourceTrigger=PropertyChanged}" />[/code]
The user has a textbox to enter/change the TaskName. If the user activates another Node, the textbox shall view the TaskName of the selected Node.
If Binding isn't supported, what could be a recommended solution?
Reply #3 - Sep 2nd, 2010 at 9:07am
You could set the last activated Task as a DataContext for the TextBox (or a panel that contains it along with other bound elements). For example:
<TextBox Name="nameBox" Text="{Binding Path=TaskName, UpdateSourceTrigger=PropertyChanged}" />
void diagram_NodeActivated(object sender, NodeEventArgs e)
	if (e.Node is Task)
		nameBox.DataContext = e.Node;
Amosius
Reply #4 - Sep 2nd, 2010 at 10:02am
Hi Stoyan,
works fine, thank you for this hint.
