Normal Topic using usercontrol as node (Read 1958 times)
kdr35
Aug 12th, 2010 at 12:15pm
I am new in mindfusion , I need to help about node types.I want to use usercontrol in node. I am using standart windows control ( button , textbox) etc. but
I dont know add usercontrol in node. How  I can do it?
Thanks...
Re: using usercontrol as node
Reply #1 - Aug 12th, 2010 at 12:32pm
Create a ControlNode instance, set its Control property and add it to the diagram.Nodes collection.
kdr35
Reply #2 - Aug 12th, 2010 at 1:22pm
I did as you said but  i have some problems Undecided
Firstly, I want to explain what i will do. I will do graph which has a lot of nodes that are a video player.
In diagram1_NodeCreated  Event ,  I created a panel and added media buttons(play , stop etc and video viewer) in that panel.
I want to answer some questions about my problems;
- Which Diagramwiever behaviour  I must choose   to above structer.
*I chose DrawControls but I didnt link my nodes (c# panel) when ı changed behaviour to anything such as DrawShapes I can link nodes but I dont use panel in nodes , program draws default shapes. I didnt use panel in node.
thanks for helps...
Reply #3 - Aug 12th, 2010 at 1:58pm
Set Behavior to LinkControls to allow drawing links between ControlNodes. That won't work if the hosted controls capture the mouse input, but it should be fine with Panels.
