Normal Topic Problem with the new Id property for DiagramNodes (Read 1351 times)
lue
I love NetDiagram!
Aug 13th, 2010 at 10:53am
Dear all (dear Stoyo),
we used in the past for shapeNodes and DiagramLinks the Tag as identifier. Now we changed to the newest version 3.1.1 and in our application from "Tag" to the new "Id" using as identifier.
Issue: If you save the diagram in Diagram-Files, xml-Files ... you dont find this property in the files (property named "id" is the index-Value ...). We need this property in the saved files because we compare diagramitems of saved and actual diagrams ...
Do you have a solution? Do you plan to implement this property in the diagram files? I think its an urgently problem ...
best regards chris
Re: Problem with the new Id property for DiagramNo
Reply #1 - Aug 13th, 2010 at 11:50am
Hi Chris,
This property is not officially released for Netdiagram yet, we'll have to implement it for the Java and Silverlight applets first. You might still use it in ImageMap mode, but Ids are saved automatically only if they are from a value type. Otherwise the Diagram object raises the same SerializeTag and DeserializeTag events to let you run custom serializaton code. The EventArgs object now has a new PropertyName member that lets you distinguish the two cases.
Best regards,
