Hot Topic (More than 10 Replies) New column for ResourceView? (Read 15899 times)
leSasch
Aug 16th, 2010 at 7:51am
is it possible to add another column (just like the fixed first one on the very left side of the control) to the resource view?
If it possible, can you give a hint how to do it?
Thanksalot!
Sascha
Re: New column for ResourceView?
Reply #1 - Aug 16th, 2010 at 9:07am
I am afraid this is currently not possible. Can you supply me with an image of what you want to achieve? I might be able to come up with a solution.
springy
Reply #2 - Aug 16th, 2010 at 10:21am
Consider for example a 2-timeline (Day + 2-Hours) for 7 days resource view:
Focus is on the second (inner most) timeline header: The first (header-less) column contains the resource name (and an +/- expander) and then followed by columns 12*7=84 columns "00, 02, 04, 06, .. 22, 00, ..".
I now would like to have 2 missing things:
1. an header for the resource (=first column) at all
2. 1 or more additional columns between the first column and the 84 timeline columns to show resource-specific details. Ideally with an header-column click-event for providing sorting functionality against the detail column.
/\/\arkus.
Reply #3 - Aug 16th, 2010 at 10:31am
An option would be to make the resource row headers customizable through templates. This way, you can define your template to consist of two columns - one for the resource name and one for the resource-specific details. We have to check and see if we can implement this design for the next release of the component.
Reply #4 - Aug 18th, 2010 at 6:13am
We have made some modifications to the control to allow the resource headers in the Resource views to be customizable through templates. A sample, containing the new version of the control as well as illustrating how to replace the default resource header template can be downloaded from the link below:
https://mindfusion.eu/_samples/_sample_CustomResourceHeaders.zip
Let me know if this works for you. I will send you a licensed build.
springy
Reply #5 - Aug 20th, 2010 at 8:03am
Thanx, that's already helpful.
Is it already possible to change the (top-)header of this custom drawn left-most header-column? So that I could label the 2 grid parts "resource | details" once?
/\/\arkus.
Reply #6 - Aug 20th, 2010 at 11:25am
This is not currently possible but we will think of a way to extend the control further to enable such customization. I will keep you updated.
Reply #7 - Aug 23rd, 2010 at 6:04am
This sample contains a new version of the control which enables customization of the portion of the timeline headers located above the resource headers.
https://mindfusion.eu/_samples/_sample_CustomResourceHeaders2.zip
Let me know if this helps.
springy
Reply #8 - Aug 23rd, 2010 at 8:02am
On the right way Smiley
I tried to detect which header-lane (timeline) I'm on by changing Text="Male" into Text="{Binding Settings.Unit}"but both lines now display "Month" -- since in debugger the ResourceViewSettings-Bottom/Middle/Top-TimelineSettings show up as Day/Month/Year I assume there is some assignment problem for the TimelineHeader context?
/\/\arkus.
Reply #9 - Aug 23rd, 2010 at 8:22am
This is a bug. Here is a fixed version:
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Wpf.2.2a.zip
springy
Reply #10 - Aug 23rd, 2010 at 9:51am
Better Smiley
All the Settings.HeaderStyle-Bindings are not working for TimelineHeader.Settings -- should I replace "Settings.HeaderStyle" with "Calendar.ResourceViewSettings.HeaderStyle" or should class TimelineHeader contain a reference to these settings?
/\/\arkus.
springy
Reply #11 - Aug 23rd, 2010 at 9:55am
BTW: Margin="{Binding Settings.CalendarStyle.Background}" doesn't make much sense  Wink   (I know these typically copy-paste artifacts)
/\/\arkus.
Reply #12 - Aug 23rd, 2010 at 10:27am
Our developers seem to have messed up the sample in the haste. Replacing "Settings.HeaderStyle" with "Settings.CalendarStyle" seems to be more aprropriate if you want to use the style of the corresponding timeline. You can also remove the wrong margin and instead specify the following margin on the text blocks:
Margin="{Binding Settings.CalendarStyle.ContentMargin}"
Kind regards,
springy
Reply #13 - Sep 22nd, 2010 at 3:27pm
Is this latest version already available as non-trial version?
It looks like I have several different 2.2.0 versions and the download center nowhere shows release dates.
/\/\arkus.
leSasch
Reply #14 - Sep 22nd, 2010 at 3:40pm
The today version on clientsarea.eu is the same as the one from 16th August this year.  Shocked
