Very Hot Topic (More than 25 Replies) ItemClick does't works! (Read 6491 times)
Mandy
Sep 4th, 2023 at 4:02am
Hi ,
I'm running Sample Browser - Scheduling.WPF (3.5.1.451).
The Framework is .Net Framework 4.7.2
1)Sample-Localization : ItemClick event not firing.
2)Sample-DualView : The prev/next month is incorrect.
« Last Edit: Sep 4th, 2023 at 7:20am by Mandy »
Re: ItemClick does't works!
Reply #1 - Sep 4th, 2023 at 3:06pm
Hi Mandy,
ItemClick is raised when you click an appointment. E.g. select some cells and type on the keyboard to create appointment; clicking it afterwards should raise the event as expected. If you need to detect clicks on empty date cells, handle the DateClick event instead.
Reply #2 - Sep 4th, 2023 at 3:17pm
The calendar has a separate ScrollInterval property controlling that, you could set it to 1 or 2 depending on how much you want to offset the current range.
<planner:MonthRangeSettings ScrollInterval="2" ...
(the default ScrollInterval is 4 to match default NumberOfMonths, but they are not bound to each other and can be set independently).
Mandy
Reply #3 - Sep 5th, 2023 at 12:06pm
Hi Slavcho,
My project is use the MaterialDesignThemes.
The appointment subject will overlapping text during edit mode.
Is there any way to solve it ?
Thanks for your help!
Reply #4 - Sep 5th, 2023 at 1:29pm
Hi Mandy,
It seems your theme sets global transparent background for textboxes, and the appointment behind the inplace-edit textbox remains visible too. You can replace that background with solid color specifically for textboxes inside the calendar:
<planner:Calendar ...>
	<planner:Calendar.Resources>
		<Style TargetType="{x:Type TextBox}">
			<Setter Property="Background" Value="White" />
		</Style>
	</planner:Calendar.Resources>
</planner:Calendar>
Mandy
Reply #5 - Sep 6th, 2023 at 9:02am
Hi Slavcho,
Is there any way to solve below problems ?
1)How to change the text color of the button at the top of the window?
2)How to set location?
3)How to make the description warp text ?
4)What is the purpose of this field?
5)The arrow icons are not shown.
6)How to set the time zone?
Is is there have any XAML sample of AppointmentForm and RecurrenceForm (Like 4.png)?
« Last Edit: Sep 6th, 2023 at 10:22am by Mandy »
Mandy
Reply #6 - Sep 7th, 2023 at 6:45am
Hi Slavcho,
How to detect these events ?
1)The subject changed.
2)The Appointment Form save or delete clicked.
Reply #7 - Sep 7th, 2023 at 9:21am
Try this code -
var form = new AppointmentForm(...);
var panel = (Panel)form.Content;
var toolbar = (ToolBar)panel.FindName("toolBar1");
toolbar.Foreground = Brushes.Orange;
foreach (Button button in toolbar.Items)
	button.Foreground = Brushes.Orange;
Reply #8 - Sep 7th, 2023 at 9:25am
That dropdown lists Schedule.Locations objects.
Reply #9 - Sep 7th, 2023 at 9:27am
It does wrap text by default, do you mean you want it to scroll instead?
Reply #10 - Sep 7th, 2023 at 9:32am
It lists schedule.Contacts, lets you select ones associated with the appointment.
Mandy
Reply #11 - Sep 7th, 2023 at 9:40am
=>I cannot input wrap text. Can't type Enter or Shift+Enter.
Reply #12 - Sep 7th, 2023 at 9:42am
Arrow icons are paths set as content of buttons inside DateTimePicker control:
<Button Name="buttonUp"  VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch" Margin="0,0,0,-1" VerticalAlignment="Center" HorizontalAlignment="Center" Grid.Column="11" BorderThickness="0">
	<Path Fill="Black" Data="M 5 1 L 9 8 L 1 8 z" Stretch="Uniform" />
</Button>
<Button Name="buttonDown"  HorizontalContentAlignment="Stretch" VerticalContentAlignment="Stretch" Margin="0,-1,0,0" Grid.Row="1" HorizontalAlignment="Center" VerticalAlignment="Center" Grid.Column="11" BorderThickness="0">
	<Path Fill="Black" Data="M 5 8 L 1 1 L 9 1 z" Stretch="Uniform" />
</Button>
Not sure why they would hide, please attach a test project demonstrating that.
Reply #13 - Sep 7th, 2023 at 9:49am
The standard form does not support selecting time zones at this time. Anyway if you need that many customizations, you might be better off just creating a new form altogether, to set the ten or so properties of appointments.
Reply #14 - Sep 7th, 2023 at 9:52am
Try handling ItemInplaceEdited event.
