Normal Topic Exception on calendar load (Read 9364 times)
tavo
Dec 3rd, 2011 at 10:00am
I use the following xaml code on my simple application
<Window x:Class="Form_Prenotazioni"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    Height="700" Width="700" xmlns:planner="http://mindfusion.eu/scheduling/wpf">
    <planner:Calendar Name="calendar" CurrentView="Timetable" Theme="Silver">
	  <planner:Calendar.TimetableSettings>
		<planner:TimetableSettings ShowCurrentTime="True" />
	  </planner:Calendar.TimetableSettings>
    </planner:Calendar>
</Window>
the proble is that when I Show the window with the Calendare control appears the following Exception on Output window of VS2010
 System.Windows.Data Error: 2 : Cannot find governing FrameworkElement or FrameworkContentElement for target element. BindingExpression:Path=HeaderTextRotation; DataItem=null; target element is 'RotateTransform' (HashCode=46809697); target property is 'Angle' (type 'Double')
and whe i try to create a new appointement this Exception
System.Windows.Data Error: 40 : BindingExpression path error: 'DescriptionText' property not found on 'object' ''ItemPresenter' (Name='')'. BindingExpression:Path=DescriptionText; DataItem='ItemPresenter' (Name=''); target element is 'TextBlock' (Name=''); target property is 'Text' (type 'String')
thanks in advance
Re: Exception on calendar load
Reply #1 - Dec 5th, 2011 at 8:28am
These are just binding expression errors that should not have any impact on the application. In any case, I am not able to reproduce them here. Can you send me your application or another sample illustrating this problem to meppy@mindfusion.eu?
tavo
Reply #2 - Dec 5th, 2011 at 1:48pm
I divided the routine that create the appointement on the control Calendar.
To populate of appointements do not take long time, the exception an the time increase when the property 'Date' and 'EndDate' changed.
I show you the routine used to do this.
                    'directory
                    Dim root As String = "..."
                    'get the information about directory
                    Dim dir As New System.IO.DirectoryInfo(root)
                    'get the files list
                    Dim fileList = dir.GetFiles("*.*", System.IO.SearchOption.TopDirectoryOnly)
                    'analized only files txt called with b...
                    Dim fileQuery = From file In fileList _
                                    Where file.Name Like "*.txt" And file.Name Like "b*"
                                    Order By file.Name
                                    Select file
                    'declaration of a form with calendar control
                    Dim Form_Prenotazioni As New Form_Prenotazioni
                    'Create new appointment
                    Dim app As Appointment = Nothing
                    'Create new resource
                    Dim resource As Resource = Nothing
                    'To split the string into txt file
                    'Dim ParamSeparator() As Char = {";"}
                    For Each file In fileQuery
                        'new resource
                        resource = New Resource
                        resource.Name = file.Name
                        'add resource
                        Form_Prenotazioni.calendar.ItemResources.Add(resource)
                        'read file
                        Dim r As New IO.StreamReader(file.FullName)
                        'analized all content
                        While Not r.EndOfStream
                            'divido ogni riga in stringhe separate da ";"   startdate; enddate; header
                            Dim Stringa() As String = r.ReadLine.Split(ParamSeparator)
                            'startdate
                            If Stringa.Length > 2 Then
                                'only this year
                                If Now.Year = CDate(Stringa(0)).Year Then
                                    'new appointement
                                    app = New Appointment
                                    'set the header
                                    app.HeaderText = Stringa(2)
                                    'set the date
                                    app.StartTime = New DateTime(CDate(Stringa(0)).Year, CDate(Stringa(0)).Month, CDate(Stringa(0)).Day)
                                    app.EndTime = New DateTime(CDate(Stringa(1)).Year, CDate(Stringa(1)).Month, CDate(Stringa(1)).Day)
                                    'add the item
                                    app.Resources.Add(Form_Prenotazioni.calendar.ItemResources(Form_Prenotazioni.calendar.ItemResources.Count - 1))
                                    app.AllDayEvent = True
                                    'aggiunge l'item alla risorsa
                                    Form_Prenotazioni.calendar.Schedule.Items.Add(app)
                                End If
                            End If
                        End While
                        'chiudo lo stream
                        r.Close()
                    Next
                    'visualizza la form
                    Form_Prenotazioni.Show()
this routine is fast the problem is on event Form_Prenotazioni.loaded
 Private Sub EventoLoaded(ByVal sender As Object, ByVal e As System.Windows.RoutedEventArgs) Handles Me.Loaded
            'Me.calendar.Date = "01/06/2011"
            'Me.calendar.EndDate = "30/06/2011"
 End sub
Reply #3 - Dec 6th, 2011 at 8:22am
The performance can be affected by various factors, including the number if items in the displayed interval and the current view settings. For example, if you are using a resource view with high resolution (for example, hours) and display an interval of 30 days, this will affect the initial load speed. You can reduce the load time roughly in half by wrapping the two assignments in a BeginInit/EndInit block:
Me.calendar.BeginInit()
Me.calendar.EndInit()
Can you also provide me with your view settings and an estimation of the number of items in the displayed interval?
tavo
Reply #4 - Dec 6th, 2011 at 9:08am
to testing the application I create 300 app into 80 itemresource to load in Calendar.
The time to create them programmatically it's no longer
 VC_ts1 = New TimeSpan(Now.Ticks)
...code to create app
 VC_ts2 = New TimeSpan(Now.Ticks)
(VC_ts2 - VC_ts1).ToString = 00:00:00.8950512
             'code to set the data
            If Me.Calendar1.SelectedDates.Count > 0 Then
                Me.Calendar1.BeginInit()
                Me.calendar.Date = Me.Calendar1.SelectedDates(0).Date
                If Me.Calendar1.SelectedDates(Me.Calendar1.SelectedDates.Count - 1).Date >= Me.calendar.Date Then
                    Me.calendar.EndDate = Me.Calendar1.SelectedDates(Me.Calendar1.SelectedDates.Count - 1).Date
                Else
                    Me.calendar.EndDate = Me.calendar.Date.AddDays(7)
                End If
                Me.Calendar1.EndInit()
            End If
(VC_ts2 - VC_ts1).ToString = 00:00:48.5137749
xaml code is the same code I find on simple for vs2010 distribuited with the pack
       <planner:Calendar Name="calendar" CurrentView="ResourceView" GroupType="GroupByResources" Date="6/1/2011" EndDate="6/30/2011" Margin="12,71,197,12">
            <planner:Calendar.ItemSettings>
                <planner:ItemSettings ResizeBandSize="0" MoveBandSize="0" UseExtendedStyles="False" HeaderSize="60" />
            </planner:Calendar.ItemSettings>
            <planner:Calendar.ResourceViewSettings>
                <planner:ResourceViewSettings EnableSnapping="True" SnapUnit="Day" LaneSize="60" ExpandableRows="False">
                    <planner:ResourceViewSettings.HeaderStyle>
                        <planner:CalendarStyle Background="LightGray" Foreground="Black" />
                    </planner:ResourceViewSettings.HeaderStyle>
                    <planner:ResourceViewSettings.BottomTimelineSettings>
                        <planner:TimelineSettings Format="ddd" Size="24" ShowCurrentTime="False">
                            <planner:TimelineSettings.CalendarStyle>
                                <planner:CalendarStyle Background="LightGray" Foreground="Black" FontFamily="Verdana" FontWeight="Normal" />
                            </planner:TimelineSettings.CalendarStyle>
                        </planner:TimelineSettings>
                    </planner:ResourceViewSettings.BottomTimelineSettings>
                    <planner:ResourceViewSettings.MiddleTimelineSettings>
                        <planner:TimelineSettings Unit="Week" UnitCount="1" Format="MMM dd" Size="24" ShowCurrentTime="False">
                    </planner:ResourceViewSettings.MiddleTimelineSettings>
                </planner:ResourceViewSettings>
            </planner:Calendar.ResourceViewSettings>
        </planner:Calendar>
the strange is that the same operation in WindowsForm with the same condition is more fast than WPF
thanks for your help
Reply #5 - Dec 6th, 2011 at 1:31pm
Currently the resource view's load speed is proportional to the number of items, resources, the displayed time interval and the view resolution, because the view creates the visual presentation of all elements at the start. We are currently in the process of implementing virtualization in this view but I am not yet able to give you an estimate of when it will be publicly available. Stay tuned for updates regarding this issue in the near future.
