Normal Topic Tree Layout and Reorgnaize nodes (Read 1561 times)
rajesh_patil74
Aug 25th, 2010 at 9:45am
Hi Stoyo
I am generating a orgnogram using "TreeLayout".
Now once the tree is generated, I am allowing user to re-position/resize the nodes.
For eq. allowing user to resize the nodes should re-arrange all downlevel nodes
Or
Re-positioning the node should re-arrange all nodes on same level and downlevel for all nodes.
I tried to re-arrange the nodes & links which are in downlevel but not working as expected.
-Regards
Rajesh
Re: Tree Layout and Reorgnaize nodes
Reply #1 - Aug 25th, 2010 at 11:59am
Hi Rajesh,
Changing the order of a node relatively to its siblings can be done by changing the index of the link that connects it to its parent in the parent's OutgoingLinks collection. E.g. if you want a node to become leftmost under its parent, remove the corresponding link from parent.OutgoingLinks and insert it at index 0.
I suppose you'll have to re-arrange the tree branch that starts from the parent node after that, by setting TreeLayout.Root and enabling KeepRootPosition.
