Normal Topic Node and Anchor point selection (Read 4530 times)
Naganathan
Aug 25th, 2010 at 12:02pm
Hi Stoyo,
You have any idea on how to implement the following functionality?
I want to move the node when the node is clicked and dragged instead of start creating link and link should be created only when i click on any of the anchor points.
Currently what happens is the node is moved only when clicked at center and dragged..if i click any place other than the node center,the diagram starts creating a link from the nearest anchor point..though i set AutoSnapLinks to "false" and AutoSnapDistance to 0 still it takes the nearest anchor point when dragged and creates a link instead of moving the node..
And this makes moving the node very difficult (specially when the node size is small)..
Appreciate your help..
Naganathan NS.
Re: Node and Anchor point selection
Reply #1 - Aug 25th, 2010 at 1:52pm
Assign an instance of this class to diagram.CustomBehavior:
public class MyBehavior : DrawShapesBehavior
	public MyBehavior(Diagram diagram) : base(diagram) { }
	public override InteractionState StartDraw(Point point)
		var node = Diagram.GetNodeAt(point, true);
		if (node != null)
			if (GetAnchorAt(node, point) != null)
				var link = CreateLink(node, point);
				Diagram.Links.Add(link);
				return new InteractionState(link, Action.Create, link.ControlPoints.Count - 1, point);
			return new InteractionState(node, Action.Modify, 8, point);
		return base.StartDraw(point);
	static AnchorPoint GetAnchorAt(DiagramNode node, Point point)
		foreach (AnchorPoint ap in node.AnchorPattern.Points)
			Rect r = node.Bounds;
			Point p = new Point(
				r.Width * ap.X / 100 + r.X,
				r.Height * ap.Y / 100 + r.Y);
			if (p.Distance(point) < 10)
				return ap;
		return null;
Naganathan
Reply #2 - Aug 26th, 2010 at 12:35pm
Thanks Stoyo...it works as expected...
Naganathan NS.
