Hot Topic (More than 10 Replies) Memory Exception in Windows 2008 (64 bit)   (Read 6449 times)
manu
Manu bhai moter chale
pum pum pum...
Aug 30th, 2010 at 4:58am
I am using NetDiagram 3.0.1 and getting following exception when generating flowchart in Windows 2008 (64-Bit) Environment, whereas same code is working perfectly fine in Windows 2003 (32 bit).
Exception of type 'System.Web.HttpUnhandledException' was thrown.
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
**Does NetDiagram has any issue with 64 bit environment or do you have a different 64-bit version of netdiagram?
Regards
Manu
Regards&&Manoj
Re: Memory Exception in Windows 2008 (64 bit)
Reply #1 - Aug 30th, 2010 at 11:18am
What Diagram or DiagramView methods are shown in the call stack? We build the project using the AnyCPU option, and it should run on both 32-bit and 64-bit versions of the framework. We haven't tried it on a 2008 server though, we'll check it later this week.
manu
pum pum pum...
Reply #2 - Aug 31st, 2010 at 1:10am
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.]
   MindFusion.Diagramming.ShapeNode.SaveToXml(XmlElement xmlElement, XmlPersistContext context) +0
   MindFusion.Diagramming.XmlPersistContext.xcfee0917c3bf82cc(DiagramItem xccb63ca5f63dc470, XmlElement x1ea18269223b2a9c, String x121383aa64985888) +362
   MindFusion.Diagramming.Diagram.SaveToXml(XmlDocument document, Boolean includeUnalteredProperties) +869
   MindFusion.Diagramming.WebForms.DiagramView.SaveToXml(XmlDocument document, Boolean includeUnalteredProperties) +36
   MindFusion.Diagramming.WebForms.DiagramView.xa45b9f6fb2389318(SaveToStringFormat
x5786461d089b10a0, Boolean x359efee92cf48af2, Boolean x4acbb041c2d5f0a1) +414
   MindFusion.Diagramming.WebForms.DiagramView.SaveControlState() +57
   System.Web.UI.Page.SaveAllState() +275
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3864
Version Information: Microsoft .NET Framework Version:2.0.50727.4206; ASP.NET Version:2.0.50727.4205
Regards&&Manoj
manu
pum pum pum...
Reply #3 - Aug 31st, 2010 at 1:14am
Following is the sample code i am using to generate the diagram
Public Class Type
       Public Const CHECKLIST As String = "CHECKLIST"
       Public Const PROCESS As String = "PROCESS"
       Public Const START As String = "START"
       Public Const [END] As String = "END"
       Public Const [STEP] As String = "STEP"
    End Class
    Private Function GetBrush(ByVal sShapeType As String) As MindFusion.Drawing.Brush
       Dim myBrush As MindFusion.Drawing.Brush
       Select Case sShapeType
           Case Type.CHECKLIST
               myBrush = New MindFusion.Drawing.SolidBrush(Color.FromArgb(255, 170, 42))
           Case Type.PROCESS
               myBrush = New MindFusion.Drawing.SolidBrush(Color.FromArgb(102, 204, 255))
           Case Type.START, Type.END
               myBrush = New MindFusion.Drawing.SolidBrush(Color.FromArgb(158, 183, 211))
           Case Type.STEP
               myBrush = New MindFusion.Drawing.SolidBrush(Color.FromArgb(178, 195, 70))
           Case Else
               myBrush = New MindFusion.Drawing.SolidBrush(Color.Red)
       End Select
       Return myBrush
    End Function
    Private Function GetDiagramLink(ByVal DG As Diagram, ByVal parentNode As DiagramNode, ByVal childNode As DiagramNode) As DiagramLink
       Dim myLink As New DiagramLink(DG, parentNode, childNode)
       myLink.HeadShape = ArrowHead.BowArrow
       myLink.Pen = New MindFusion.Drawing.Pen(Color.SteelBlue, 0.2)
       myLink.Brush = New MindFusion.Drawing.SolidBrush(Color.SteelBlue)
       myLink.Dynamic = True
       myLink.ShadowOffsetX = 0
       myLink.ShadowOffsetY = 0
       myLink.Locked = False
       Return myLink
    End Function
    Public Sub DrawFlowChart()
       dgv.ImageFormat = "image/jpeg"
       dgv.ImageQuality = 75
       dgv.MaxImageSize = New Size(1000, 1000)
       dgv.Behavior = Diagramming.Behavior.DoNothing
       dgv.BorderWidth = 0.2
       dgv.BorderStyle = BorderStyle.Solid
       dgv.BorderColor = Color.Gray
       Dim DG As Diagram = dgv.Diagram
       If DG Is Nothing Then Exit Sub
       DG.ClearAll()
       DG.BackBrush = New MindFusion.Drawing.SolidBrush(Color.White)
       DG.SelectAfterCreate = False
       DG.LinkHeadShape = ArrowHead.BowArrow
       DG.LinkHeadShapeSize = 2
       Dim dt As DataTable = GetData()
       If dt IsNot Nothing AndAlso dt.Rows.Count > 0 Then
           dgv.Diagram.DefaultShape = Shapes.Rectangle
           Dim factory As Factory = dgv.Diagram.Factory
           Dim PRVNODE As ShapeNode = Nothing
           For Each dr As DataRow In dt.Rows
               Dim newNode As ShapeNode = factory.CreateShapeNode(0, 0, 50, 25)
               newNode.EnableStyledText = True
               newNode.Brush = GetBrush(dr("TYPE"))
               newNode.ShadowOffsetX = 1
               newNode.ShadowOffsetY = 1
               newNode.ZTop()
               newNode.Obstacle = True
               Select Case dr("type").ToString
                   Case Type.START
                       newNode.Shape = Shapes.Start
                       newNode.Text = "START"
                       newNode.Resize(40, 20)
                   Case Type.END
                       newNode.Shape = Shapes.Terminator
                       newNode.Text = "END"
                   Case Type.PROCESS
                       newNode.Shape = Shapes.Procedure
                       newNode.Text = "Process"
                   Case Type.STEP
                       newNode.Shape = Shapes.RoundRect
                       newNode.Text = "Step"
                   Case Type.CHECKLIST
                       newNode.Shape = Shapes.BpmnIntermediateRule
                       newNode.Text = "Checklist"
               End Select
               DG.Nodes.Add(newNode)
               If PRVNODE IsNot Nothing Then
                   Dim nodeLink As DiagramLink = GetDiagramLink(DG, PRVNODE, newNode)
                   DG.Links.Add(nodeLink)
               End If
               PRVNODE = newNode
           Next
           Dim flowChart As New MindFusion.Diagramming.Layout.FlowchartLayout
           flowChart.Arrange(DG)
           DG.ResizeToFitItems(10)
       End If
    End Sub
    Protected Sub btnGenerate_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles btnGenerate.Click
       DrawFlowChart()
    End Sub
Regards&&Manoj
manu
pum pum pum...
Reply #4 - Sep 3rd, 2010 at 8:09am
I am still waiting for the solution.........
Cry Cry
Regards&&Manoj
Reply #5 - Sep 3rd, 2010 at 8:23am
Sorry, we are waiting for the delivery of our new test system to install Win2k8. We could try it on VPC, but working with VS and debugging under virtualization is awfully slow.
manu
pum pum pum...
Reply #6 - Sep 8th, 2010 at 4:40am
still waiting... Cry Cry Cry
Could you please let me know how much more time it may take to test this issue...
Regards&&Manoj
Reply #7 - Sep 8th, 2010 at 7:05am
We'll be setting up the system today. What ASP.NET runtime version are you using?
Reply #8 - Sep 8th, 2010 at 8:05am
In addition, are you getting this problem on Windows Server 2008 or Windows Server 2008 R2?
manu
pum pum pum...
Reply #9 - Sep 9th, 2010 at 5:36am
We are using:
Web Server Machine:
ASP.NET 3.5
Windows Server 2008 (64-bit)
Development Machine:
Windows XP SP3
Regards
Manoj
Regards&&Manoj
Reply #10 - Sep 9th, 2010 at 1:38pm
The exception happens with version 3.0.1 indeed, but not with the latest 3.1.1, so I suppose it's time for you to upgrade.
