Normal Topic How to detect DiagramLink disconnect (Read 3028 times)
stefski
Aug 30th, 2010 at 10:44am
I am struggling somewhat to figure out how to detect when a DiagramLink has been disconnected from a DiagramNode.
Basically I would expect to get information about the link, endpoint (Origin or Destination) and node involved in the disconnect.
I have tried handling (among others) the LinkModified and DestinationAnchorChanged events, but they either don't fire often enough or provide too little information.
Suggestions are very welcome!
Best regards
Steffen Skov
principal consultant
SPTGroup AS
Kind regards
Steffen Skov
OLGA Application Architect
Schlumberger Information Solutions AS
Re: How to detect DiagramLink disconnect
Reply #1 - Aug 30th, 2010 at 1:47pm
If you need to know when a link is no longer connected to a node, handling LinkModified should be enough:
private void diagram_LinkModified(object sender, LinkEventArgs e)
	if (e.AdjustmentHandle == 0 && e.Link.Origin is DummyNode)
		Debug.WriteLine("disconnected origin");
	if (e.AdjustmentHandle == e.Link.ControlPoints.Count - 1 && e.Link.Destination is DummyNode)
		Debug.WriteLine("disconnected destination");
Unfortunately the event arguments do not include a reference to the origin or destination before disconnecting. If you need that, you can save reference to the respective node from a LinkStartModifying handler.
stefski
Reply #2 - Sep 1st, 2010 at 8:07am
Thank you, Stoyan!
I solved the problem by adding some state to my event handling class, which would then be able to fire my own events on connecting and disconnecting.
Best regards
Steffen Skov
SPTGroup AS
Kind regards
Steffen Skov
