Normal Topic Menu popping up below java applet (Read 2784 times)
jgreen
Aug 30th, 2010 at 9:39pm
Ok, next thing.
I have a 3rd party menu that pops up when I right click a node with various options.  All works well in Internet Explorer but in Chrome & Firefox, the menu displays below the diagram applet.
Is there a way to force this not to happen?
Re: Menu popping up below java applet
Reply #1 - Aug 31st, 2010 at 11:13am
You have a few options...
Use an IFrame shim to cover the applet and show the menu in it:
http://www.oratransplant.nl/2007/10/26/using-iframe-shim-to-partly-cover-a-java-...
Create menus using TableNodes:
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=125424382...
Or, handle nodeClicked from Java and use the Swing context menu class.
jgreen
Reply #2 - Aug 31st, 2010 at 3:42pm
Tried this method already and didn't work.
Tried this before as well and was buggy. Sometimes it appeared on top and sometimes below the shape. I assume I could try adding code to force it to the top but didn't like that it was just another shape and users could select it, drag it around, and link it to other shapes.
No idea how to do this.
jgreen
Reply #3 - Aug 31st, 2010 at 9:33pm
ok, I gave the CreateTableNode method another shot and got it to where it will work.
What should have took several minutes took hours going through the "help" file and searching these forums for clues on how to do some of the things I wanted.
I REALLY WISH there were better help files available (with examples) especially in the javascript/java areas as there are no intellisense features to help give some clues.
To help prevent others the same agony, here's what I came up with.
        var menu = null;
        function showContextMenu(node, mousePos)
var dvApplet = document.getElementById("dgvMain");
        var scriptHelper = dvApplet.getScriptHelper();
        var diagView = dvApplet.getDiagramView();
        var diagram = diagView.getDiagram();
        if (!menu)
            menu = diagram.getFactory().createTableNode(mousePos.getX(), mousePos.getY(), 60, 42.5);
            menu.setRowCount(7);
            menu.setColumnCount(2);
            menu.getCell(0, 0).setText("A");
            menu.getCell(1, 0).setText("Option A");
            menu.getCell(0, 1).setText("B");
            menu.getCell(1, 1).setText("Option B");
            menu.getCell(0, 2).setText("C");
            menu.getCell(1, 2).setText("Option C");
            menu.getCell(0, 3).setText("D");
            menu.getCell(1, 3).setText("Option D");
            menu.getCell(0, 4).setText("E");
            menu.getCell(1, 4).setText("Option E");
            menu.getCell(0, 5).setText("F");
            menu.getCell(1, 5).setText("Option F");
            menu.getCell(0, 6).setText("G");
            menu.getCell(1, 6).setText("Cancel");
        var cols = menu.getColumns();
        cols.get(0).setWidth(6);
        menu.setCaptionHeight(0);
        menu.setCaption("");
        menu.setRowHeight(50);
        menu.setAllowIncomingLinks(false);
        menu.setAllowOutgoingLinks(false);
        menu.setCellFrameStyle(1); menu.getCell(0, 0).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 1).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 2).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 3).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 4).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 5).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.getCell(0, 6).setTextFormat(scriptHelper.createTextFormat(1, 1, true, false));
        menu.setBrush(scriptHelper.createSolidBrush(255, 255, 255));
        menu.getCell(0, 0).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 1).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 2).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 3).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 4).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 5).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.getCell(0, 6).setBrush(scriptHelper.createSolidBrush(200, 200, 200))
        menu.zTop();
        else
        menu.setVisible(true);
        menu.moveTo(mousePos.getX(), mousePos.getY());
        menu.zTop();
        function onClicked(sender, args) {
            hideMenu();
        function onCellClicked(sender, args)
            menu.setVisible(false);
            var mnuOpt = args.getRow();
            if (mnuOpt == 0) {
                curNode.setText(curNode.getText() + '\nOption A Selected');
            if (mnuOpt == 1) {
                curNode.setText(curNode.getText() + '\nOption B Selected');
            if (mnuOpt == 2) {
                curNode.setText(curNode.getText() + '\nOption C Selected');
            if (mnuOpt == 3) {
                curNode.setText(curNode.getText() + '\nOption D Selected');
            if (mnuOpt == 4) {
                curNode.setText(curNode.getText() + '\nOption E Selected');
            if (mnuOpt == 5) {
                curNode.setText(curNode.getText() + '\nOption F Selected');
            if (mnuOpt == 6) {
                //cancel
        function hideMenu() {
           if (menu)
