Normal Topic Problem with removing default text in ShapeNode (Read 1994 times)
nezzy
Sep 1st, 2010 at 3:21pm
Hi.
I have an application that sets the text of the shapenode to "Enter description" when a shapenode is created.
When I dubbelclick on the shapenode I use the EnterInPlaceEditMode event to remove this text from the shapenode. This is done so the user dont have to remove the text. But I cant get the text to be removed.
What Im I missing?
Regards
Anders
private void OnNodeCreated(object sender, NodeEventArgs e)
    ShapeNode sNode = (ShapeNode)e.Node;
    sNode.Text = "Enter description";
private void diagram_EnterInplaceEditMode(object sender, InPlaceEditEventArgs e)
    if (sNode.Text == "Enter description")
        sNode.Text = ""; //Remove default text
    string myTextToEdit = e.Item.GetTextToEdit(); //Here the text is removed, but in the box on the screen is the text still there
Re: Problem with removing default text in ShapeNod
Reply #1 - Sep 1st, 2010 at 4:35pm
The edit box' text is already set when this event is raised. Set e.TextBox.Text = "" to clear it.
nezzy
Reply #2 - Sep 2nd, 2010 at 6:50am
Many thanks.
It works nicely.
Anders
