Normal Topic "rotate text" of a shapeNode (Read 2053 times)
FreizeitDuscher
Sep 1st, 2010 at 5:17pm
i'am searching for a possibility to rotate the Text of a shapeNode by 90° -without roating the node itself.
is there one?
Thank you.
Olli
Re: "rotate text" of a shapeNode
Reply #1 - Sep 1st, 2010 at 5:24pm
Only through custom-drawing or by using an attached rotated node to display the text. You can see some sample .NET drawing code here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=125084366...
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=128203790...
Let me know if you have trouble translating it to Java.
FreizeitDuscher
Reply #2 - Sep 1st, 2010 at 6:53pm
Works.
Thank you, Stoyan!
