Normal Topic 2 Questions (Read 1850 times)
ogre
2 Questions
Sep 2nd, 2010 at 12:15pm
i have 2 Questions.
1. If one can prevent, that a Containernode can drop in an anothern ContainerNode. If there is any property?
2. I drop some TableNodes in an ContainerNode and organised the Links, after that i "Folded" the ContainerNode, everything is fine.
If i modify the position, the Links are not any more in the Outgoing Position / Incomming Position of the Containernode, they are in the Outgoing Position / Incomming Position of the TableNode although the CountainerNode is "Folded".
What can I do that the Outgoing Position / Incomming Position is everytime by the Containernoder if there is "Folded"?
I hope the pictures can be illustrated what i mean.
Drop TableNode into Containernoder ...
... Folded the ContainerNode
... Reposition the ContainerNode
Re: 2 Questions
Reply #1 - Sep 2nd, 2010 at 12:49pm
1. There's no such property available. At this time you can override ContainerNode.OnDragOver and return false if the dragged item is another container.
2. I could not reproduce this. Could you email to support@mindfusion.eu a sample diagram file or test project that shows the problem? Also what version of the control are you using?
Re: 2 Questions
Reply #2 - Sep 2nd, 2010 at 7:11pm
2. Auto-routing causes this problem. It seems RoutingOptions.Anchoring = Reassign does not work with rows'  anchor points in folded containers. If you'll be using just one incoming and one outgoing point per row, you won't need the Reassign option anyway and can disable it.
ogre
Re: 2 Questions
Reply #3 - Sep 3rd, 2010 at 7:30am
Hi Stoyan,
it works! Thanks a lot.
Cheers ogre
