Normal Topic Copy / Paste Ctrl+C / Ctrl+V for multi-selection (Read 1591 times)
chieh
Sep 3rd, 2010 at 10:23am
Currently, I am using JavaApplet Mode for diagram.
I have two questions in copy/paste on multi-selection nodes
The 1st is,
Is it possible to do copy and paste for multi selection on shapes when clicking the javascript function contains
var applet = <%= diagramView.AppletElement %>;
applet.copyToClipboard();
applet.pasteFromClipboard(10, 10);
? And then the 2nd question is,
Is it possible to enable keyboard's ctrl+c and ctrl+v for copy/past?
Any suggestions?
Many thanks
Re: Copy / Paste Ctrl+C / Ctrl+V for multi-selecti
Reply #1 - Sep 3rd, 2010 at 11:49am
1. It should be possible doing that from the ClickedScript JS handler.
2. Try setting KeyPressScript to the following.
function onKeyPress(sender, args)
	//alert(args.getKeyChar());
	var CtrlC = 3;
	var CtrlV = 22;
	var CtrlX = 24;
	if (args.getKeyChar() == CtrlC)
	if (args.getKeyChar() == CtrlV)
