Normal Topic wrong link orientation from anchor point (Read 4372 times)
bgrupp
Sep 8th, 2010 at 2:13pm
It is possible to set the start/end orientation of a link from his anchor point. Currently the anchor point is attached on the left side of the node and the routed link starts horizontally. What i want is that the links start vertically.
Re: wrong link orientation from anchor point
Reply #1 - Sep 8th, 2010 at 2:21pm
Hi, do you mean you want the link to be routed vertically along the node's vertical left side?
bgrupp
Reply #2 - Sep 9th, 2010 at 6:40am
Yes, thats is what i want. It's a custom draw node with an anchor point on the left vertical side and the attached link should be vertical.
Reply #3 - Sep 10th, 2010 at 2:35pm
Would this kind of locking work for you?
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=128332086...
We could implement it for the next release if it's such a popular feature.
bgrupp
Reply #4 - Sep 13th, 2010 at 6:35am
Here's a sample image of the current node. What i want is that the link on the left side should goes upwards.
Reply #5 - Sep 16th, 2010 at 5:54am
It seems GridRouter has some support for this. Try the following settings.
diagram.RouteLinks = true;
diagram.RoutingOptions.StartOrientation = Orientation.Vertical;
diagram.RoutingOptions.EndOrientation = Orientation.Vertical;
diagram.LinkRouter = new GridRouter();
If that will work for you, we can make it customizable per individual anchor points or links.
bgrupp
Reply #6 - Sep 17th, 2010 at 9:05am
these settings works for this type of node. But we have many other nodes which then routed wrong. I think it must be a customizable per anchor point.
Reply #7 - Sep 17th, 2010 at 11:07am
Ok, we'll try to add an AnchorPoint property that lets you specify that for the next release.
Reply #8 - Sep 24th, 2010 at 12:20pm
This version adds LinkOrientation property to AnchorPoint:
https://mindfusion.eu/_beta/wpfdiag_aporient.zip
At this time it works only when using GridRouter. In addition RoutingOptions.Anchoring must be different from Ignore, and the link's shape must be set to Cascading.
