Normal Topic OnMouseMove (Read 1059 times)
Nedor
OnMouseMove
Sep 14th, 2010 at 8:04am
For customized adding of nodes or links, i created my own BehaviorBase derivated class.
If the mousecurser is moved over a node, I change the mousecursor depending of some checking functions which determines, if adding a link for this node is possible or not.
But OnMouseMove is only called during drag operations. Is there any way to get the mouseMove event in my BehaviorBase derivated class if no drag operation is running?
Re: OnMouseMove
Reply #1 - Sep 14th, 2010 at 8:56am
You could handle the DiagramView.MouseMove event and call that method on your behavior object. Or you might override SetMouseCursor to change the cursor when not dragging.
