Normal Topic TypeLoadException on DateTimeFormat (Read 3137 times)
vaughandata
Sep 14th, 2010 at 4:04pm
Hi Guys,
I have just upgraded my Planner .NET (Trial Version) to the full version and when i come to run my project i get
An unhandled exception of type 'System.TypeLoadException' occurred in mscorlib.dll
Additional information: Could not load a type.  Failed to partial bind to "MindFusion.Scheduling.Style, Calendar, Version=4.1.0.19866, Culture=neutral, PublicKeyToken=9bbcdceda2685d38".
Didnt notice this on the trial version. Was wondering if anyone else has seen it and knows of a resolution
many thanks
Ian
vaughandata
Re: TypeLoadException on DateTimeFormat
Reply #1 - Sep 14th, 2010 at 4:09pm
sorry the line of code it fails on is......
Me.Calendar1.DateTimeFormat = CType(resources.GetObject("Calendar1.DateTimeFormat"), System.Globalization.DateTimeFormatInfo)
Reply #2 - Sep 15th, 2010 at 6:27am
If you aren't using any custom DateTimeFormat values, simply remove that line of code (it will be regenerated the next time you open the containing form in the designer) and try to rebuild your application. If you are using custom values, remove the line of code causing the errors and reenter the values through the designer once you have replaced the control references.
Let me know if this works.
vaughandata
Reply #3 - Sep 15th, 2010 at 8:56am
Thank you so much Meppy, that has sorted the problem
