Normal Topic Disable Deleting of Specific Nodes (Read 1047 times)
Nedor
Sep 22nd, 2010 at 7:30am
Is there any way to disable the user deletion of some nodes?
I have some nodes which are part of a group. This nodes shouldn't be deleted directly by the user. Only if the Groupowner Node is deleted they should be deleted.
Re: Disable Deleting of Specific Nodes
Reply #1 - Sep 22nd, 2010 at 10:17am
You can handle NodeDeleting and set e.Cancel = true if e.Node.MasterGroup is set. Or just set Locked = true for the attached nodes if the user is not supposed to even select them.
