Normal Topic Link snapping (Read 1441 times)
luffy911
Link snapping
Sep 28th, 2010 at 6:20pm
   I would like to implement a feature of snapping to anchor points when creating links.  For instance, I would like that when I get close to an anchor, the link would automatically connect to it visually and if I release the mouse button then the link is created.
Does anyone have suggestions on how to tackle this feature ?
Re: Link snapping
Reply #1 - Sep 28th, 2010 at 6:48pm
There are AutoSnapLinks and AutoSnapDistance properties in the Silverlight version of the control; we can port them to WinForms for the next release. You could implement this yourself by overriding DiagramLink.UpdateCreate and using the Diagram.GetNodeAt(point, threshold) and DiagramNode.GetClosestAnchorPoint(point) methods to find the position for the end point.
luffy911
Re: Link snapping
Reply #2 - Sep 28th, 2010 at 10:44pm
Hi Stoyan,
   I try it and the link draw properly to the target node.  I manage to get everything working by also overriding the AllowCreate and The CompleteCreate function since both of these function would work with the mouse position instead of the Destination.
I just called the base function by passing the Destination Location.
Luffy
