Normal Topic Display overlay on top of diagram (Read 1783 times)
johnsuarez
Sep 29th, 2010 at 2:58pm
I am trying to display an alignment overlay that displays vertical/horizontal lines (from existing shapenodes in diagram), while I am dragging around a new node ( Similar to any screen designer).  The problem is I am using the DrawNode event to paint code outside the bounds of the moving node and getting strange results (lines do not appear sometimes or in wrong spots). I have set the ShapeNodes.CustomDraw = CustomDraw.Additional2, which according to docs does not have clipping region applied.   I need a way to draw graphics anywhere on diagram after the diagram has been rendered.
Re: Display overlay on top of diagram
Reply #1 - Sep 29th, 2010 at 3:08pm
Try drawing from the Diagram.DrawForeground event handler.
johnsuarez
Reply #2 - Sep 29th, 2010 at 3:33pm
Thank you, that worked.  Had to call diagram.invalidate( true) in this event to make it work. Again thank you for you very fast response.
Reply #3 - Sep 29th, 2010 at 3:46pm
I think calling Invalidate from any drawing code will create an infinite loop of painting and invalidating... You will get the NodeModifying event raised while moving nodes around; try calling Invalidate from there.
