Normal Topic Unconnected nodes in tree (Read 1534 times)
slowjoe
Oct 1st, 2010 at 9:23pm
I have a tree layout and add a bunch of nodes that I read from a file then connect them.  I would also like to add "unconnected" nodes and have them automatically line up on the bottom or side of the view.  Is there a way to do this?
Thank you,
Joe
Re: Unconnected nodes in tree
Reply #1 - Oct 2nd, 2010 at 6:26am
Hi Joe,
Try setting TreeLayout.MultipleGraphsPlacement = MinimalArea. If you need more control over the node positions, you could do something like this:
// add and arrange tree nodes
treeLayout.Arrange(diagram);
RectangleF r = diagram.GetContentBounds(false, true);
r.Y = r.Bottom + yoffset;
// add the rest of the nodes
foreach (DiagramNode node in unconnectedNodes)
	r.Width = node.Bounds.Width;
	r.Height = node.Bounds.Height;
	node.Bounds = r;
	r.X = node.Bounds.Right + xoffset;
slowjoe
Reply #2 - Oct 4th, 2010 at 4:05pm
Hi Stoyan,
Thanks for the tip.  The second way (coding) seems to work a little better as I have more control over things.
Joe
