Normal Topic ItemCreated-Event (Read 3845 times)
alexus
ItemCreated-Event
Oct 6th, 2010 at 8:16am
i´m just testing the Schedule-Module for an upcoming project and i cant get the ItemCreated-Event working.
e.g. : i modified the 'RessourceView'-Sample with:
<planner:Calendar Name="_calendar" ... EnableDragCreate="True" ItemCreated="_calendar_ItemCreated" >
The event is neither fired when creating an item via drag&drop nor when creating via double-click and using the input-mask
Am I using the wrong event or is it a bug?
greetings
alexus
Re: ItemCreated-Event
Reply #1 - Oct 6th, 2010 at 9:03am
By design, the Calendar.ItemCreated event should be raised when the user creates an item interactively.
In this sample, when the user creates an item through the Resource form by double-clicking in the calendar, the item is added programmatically (within the OkButton_Click method of the ResourceWindow class) and therefore the event is not raised. However, when an item is created through dragging (with EnableDragCreate = true) the event should be raised. The later is a bug. I will look into it and update you when I have more information.
Reply #2 - Oct 6th, 2010 at 12:00pm
Could you try with the version below and see if the event works?
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.Wpf.2.2b.zip
alexus
Reply #3 - Oct 6th, 2010 at 12:23pm
The new version works fine.
I´m really impressed so far by the whole Module. I will convince my boss, that we should take this one. Great Control! Great Service! Great Work!
greetings
alexus
