Normal Topic calendar view customization (Read 7420 times)
vijayalakshmi
Apr 15th, 2014 at 7:44am
Hi Meppy,
Please help me on customizing the day calendar as shown in the snapshot .
Waiting for your response...
Thanks & Regards,
Viji Smiley
Re: calendar view customization
Reply #1 - Apr 15th, 2014 at 9:48am
It is not appropriate to use a calendar control for this job - you should use a data grid instead. We've modified our own WPF DataGrid control specifically to be able to display this exact table. Have you had a look at it here?
vijayalakshmi
Reply #2 - Apr 16th, 2014 at 3:29am
Yes Meppy. Thanks for the datagrid customization which you provided. It was very helpful. I had requirement where I have to provide the same data customization by using Day calendar of mindfusion scheduling. Let me know if there are any possibilities of doin this in Mindfusion scheduling Day Calendar.
Waaiting for your response..
Thanks & Regards,
Viji Smiley
Reply #3 - Apr 16th, 2014 at 12:10pm
Here is a customized Timetable view, which displays the data as a grid.
https://mindfusion.eu/_samples/_sample_CustomTimetableGrid.zip
vijayalakshmi
Reply #4 - Apr 17th, 2014 at 3:50am
Thanks Meppy...
The navigation control is moving forward to next month and backward to previous month...
I need the date to be displayed as ahown in snapshot below with current date as 17 April 2014
Can you please give the code for this...
Thanks & Regards,
viji
vijayalakshmi
Reply #5 - Apr 17th, 2014 at 5:08am
I  think the code needs to be updated in Navigation Control.cs
Please reply me on this ASAP...
Thanks ,
Viji Smiley
vijayalakshmi
Reply #6 - Apr 17th, 2014 at 5:13am
public class NavigationControl : ContentControl
           static NavigationControl()
                 DefaultStyleKeyProperty.OverrideMetadata(typeof(NavigationControl),
                       new FrameworkPropertyMetadata(typeof(NavigationControl)));
           public NavigationControl()
           public string Header
                 get { return (string)GetValue(HeaderProperty); }
                 set { SetValue(HeaderProperty, value); }
           public static readonly DependencyProperty HeaderProperty =
                 DependencyProperty.Register("Header", typeof(string), typeof(NavigationControl), new PropertyMetadata(""));
vijayalakshmi
Reply #7 - Apr 17th, 2014 at 5:17am
Day Navigation control---17Apr 2014
Week range navigation control---13-19 Apr2014
Please help me on this...
thanks,
Viji
Reply #8 - Apr 17th, 2014 at 5:58am
The text displayed in the navigation control is specified through NavigationControl.Header. In the sample this property binds directly to Calendar.Date and uses the "MMMM yyyy" format. You can change this format value to any standard date and time formatting string or you can assign Header manually in code if you need it to display a range of dates.
