Normal Topic DiagramLink custom Headshape (Read 1775 times)
johnjay981
Oct 7th, 2010 at 3:43pm
Hi
is it possible to use a custom image instead of the the predefined arrowhead (Arrow, Circle etc).
Re: DiagramLink custom Headshape
Reply #1 - Oct 7th, 2010 at 5:14pm
It is possible to set a custom Shape object as arrowhead, but not a bitmap image. If you need the latter, you can custom-draw the image by handling the DrawLink event. Here you can find some transform code that rotates around a specific point (e.g. the link end point in your case):
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=125084366...
Also search the forum for the "CarteseanToPolar" method, which lets you find a rotation angle from two points.
