Normal Topic WPF 2.4  Shipped DLL Issue (Read 10655 times)
Paul Eden
Oct 12th, 2010 at 4:52pm
Hi
We have just straed migrating to 2.4 but are finding there seems to be a dependancy on a DDL version we don't have:
{"Could not load file or assembly 'MindFusion.Graphs, Version=1.1.0.16661, Culture=neutral, PublicKeyToken=0d09f0b4914ade28' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)":"MindFusion.Graphs, Version=1.1.0.16661, Culture=neutral, PublicKeyToken=0d09f0b4914ade28"}
The version shipped with 2.4 is 1.1.0.22292
Is there a fix available for this?
Many thanks
Paul Eden
Re: WPF 2.4  Shipped DLL Issue
Reply #1 - Oct 12th, 2010 at 5:55pm
Check whether the "Use specific version" property is enabled for some of the assemblies in the reference properties window, and if so disable it. Also the assemblies' resolved path should probably be the same, pointing to the control's installation folder.
Paul Eden
Reply #2 - Oct 13th, 2010 at 9:41am
Hi Stoyan
I have checked the "Specific Version" flag and they are false for both DLLs (Diagraming and Graph).  I am also pointing at the installation directory location.
Is there anyting else I can try or will this be dependant on a patch release?
Many thanks
Paul
Reply #3 - Oct 13th, 2010 at 9:58am
You can try a clean install. Even if you had uninstalled the old version before installing the new one, the MSI service might have decided to keep the graphs.dll for some reason, and then to not overwrite it. So try uninstalling, deleting everything remaining in the MindFusion/Diagramming folder, and installing again.
Paul Eden
Reply #4 - Oct 13th, 2010 at 10:32am
Hi
I can certainly try a clean install - my only concern is that the Graph dll in the installation folder is 1.1.0.22292 - the correct version, but the diagramming dll is looking for an older one.
Paul
Reply #5 - Oct 13th, 2010 at 11:11am
The one I'm getting installed is 1.1.0.16661, so I suppose that's its latest version. I don't have any idea why the build number is smaller, perhaps we sent you a new build for some reason and our developer had created it on their system instead of our build server.
Paul Eden
Reply #6 - Oct 13th, 2010 at 11:33am
OK, that got it - The Graph dll I had must have been not getting overwritten by the instaler due to a higher version number, which I had assumed was the latest version.
Thanks, as ever, for your speedy assistance.
Paul
venki5star
Reply #7 - Oct 13th, 2010 at 11:40am
I am having the same issue. But I manage to find a workaround.
Do we have a permanent solution for this?
Castle Rider
Reply #8 - Oct 13th, 2010 at 11:47am
What other solution do you expect... The installer has the correct version of graphs.dll, so if you need to run it on other systems, just make sure it is a clean install. We'll change the major number to 2 for the next release just in case.
