Normal Topic V2.3 & 2.4 Snap-scrolling Behaviour (Read 2159 times)
Paul Eden
Oct 15th, 2010 at 1:54pm
Hi
Getting some strange behaviour when the diagram resizes, in 2 scenarios, both where a diagram is contained within a scrollviewer.
1. Diagram.ResizeToFitItems() - causes the diagram to "snap-scroll" to the top left, effectively re-setting scrol bar values to 1
2. When resizing a control on the diagram, with the diagram set to automatically expand if its bounds are breached, the diagram will "snap-scroll" again to top left (but with the added inconvienience that this happens while the left mouse button is still depressed, causing the control being resized to be turned inside-out becuse the snap-scroll action has caused the pointer to be at a position that gives the control a negative height & width). The negative values are fine, the "snap-scroll" is the problem
I'm tying to replicate this in a stand alone project, but so far without success. Has anyone else experienced such behaviour?
Paul Eden
Re: V2.3 & 2.4 Snap-scrolling Behaviour
Reply #1 - Oct 15th, 2010 at 2:51pm
Could you copy here the init code for the scroll viewer and the diagram - both Xaml markup and the code-behind?
Paul Eden
Reply #2 - Oct 18th, 2010 at 10:26am
Hi
XAML:
<ScrollViewer Margin="0,0,5,7" Grid.Row="1" Height="Auto" Width="Auto" Focusable="False" HorizontalScrollBarVisibility="Auto" VerticalScrollBarVisibility="Auto" d:LayoutOverrides="Width, Height">
<MF:Diagram x:Name="oHypothesisDiagram" ZoomFactor="100" Width="Auto" Height="Auto" MeasureUnit="WpfPoint" Bounds="0,0,640,480" NodesExpandable="False" Background="{DynamicResource FlowBGBrush}" HorizontalAlignment="Left" VerticalAlignment="Top" AllowSelfLoops="False">
<MF:Diagram.LinkPen>
<Pen Brush="#FFFF7A08" Thickness="2"/>
</MF:Diagram.LinkPen>
</MF:Diagram>
</ScrollViewer>
Code Behind:
oHypothesisDiagram.Behavior = Behavior.Custom;
oHypothesisDiagram.CustomBehavior = new BehaviorEx(oHypothesisDiagram);
oHypothesisDiagram.AllowDrop = true;
oHypothesisDiagram.NodeCreating += new NodeValidationEventHandler(oHypothesisDiagram_NodeCreating);
oHypothesisDiagram.LinkCreated += new LinkEventHandler(oHypothesisDiagram_LinkCreated);
oHypothesisDiagram.TreeCollapsed += new NodeEventHandler(oHypothesisDiagram_TreeCollapsed);
oHypothesisDiagram.TreeExpanded += new NodeEventHandler(oHypothesisDiagram_TreeExpanded);
oHypothesisDiagram.NodeModified += new NodeEventHandler(oHypothesisDiagram_NodeModified);
oHypothesisDiagram.LinkDeleted += new LinkEventHandler(oHypothesisDiagram_LinkDeleted);
oHypothesisDiagram.LinkDeleting += new LinkValidationEventHandler(oHypothesisDiagram_LinkDeleting);
oHypothesisDiagram.Background = new SolidColorBrush(Colors.Transparent);
oHypothesisDiagram.RecursiveExpand = true;
oHypothesisDiagram.Clicked += new DiagramEventHandler(oHypothesisDiagram_Clicked);
oHypothesisDiagram.NodeDeleted += new NodeEventHandler(oHypothesisDiagram_NodeDeleted);
oHypothesisDiagram.NodeModifying += new NodeValidationEventHandler(oHypothesisDiagram_NodeModifying);
oHypothesisDiagram.DragEnter += new DragEventHandler(oHypothesisDiagram_DragEnter);
oHypothesisDiagram.Drop += new DragEventHandler(oHypothesisDiagram_Drop);
oHypothesisDiagram.NodeDeleting += new NodeValidationEventHandler(oHypothesisDiagram_NodeDeleting);
oHypothesisDiagram.SizeChanged += new SizeChangedEventHandler(oHypothesisDiagram_SizeChanged);
oHypothesisDiagram.ExpandButtonClicked += new NodeEventHandler(oHypothesisDiagram_ExpandButtonClicked);
oHypothesisDiagram.ExpandButtonAction = ExpandButtonAction.RaiseEvents;
oHypothesisDiagram.CommandBindings.Add(new CommandBinding(ApplicationCommands.Copy, (sender, args) => { DiagramCopy(sender, args); }));
oHypothesisDiagram.CommandBindings.Add(new CommandBinding(ApplicationCommands.Cut, (sender, args) => { DiagramCut(sender, args); }));
Reply #3 - Oct 18th, 2010 at 1:49pm
1) This could happen if the new diagram.Bounds does not include the current scroll position anymore. In such case you might try saving ScrollX and ScrollY from before the ResizeToFit call and restoring them after that; I think the scrollbar should set its maximum value as scroll position if the new value happens to be larger than it.
2) I could not reproduce this. What does the NodeModifying event do? Also what kind of nodes are you using?
