Normal Topic SvgContent.Parse() takes 14 seconds (Read 1799 times)
LT411
Oct 20th, 2010 at 8:55pm
I am using:
MindFusion Diagramming for WinForms  MindFusion.svg v1.0.3601.31642.
Windows 7 64 bit
Dell Precision T7500
Visual Studio 2008.
The following code took 14 seconds to complete in release mode:
Dim content As New SvgContent()
content.Parse("\Block.svg")
Block.svg is 32,257 bytes and was created by a graphics artist using:
Generator: Adobe Illustrator 15.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 0
The svg contains a semi-transparent cube with other objects inside it using a variety of gradients.
This means it will take 45 seconds to display a diagram with 3 different nodes on it.
Is there anything I can do to improve the performance of loading .svg content?
LT411
Re: SvgContent.Parse() takes 14 seconds
Reply #1 - Oct 21st, 2010 at 7:17am
SVG parsing speed was improved in the V5.3.1 release; which Flowchart.NET version are you using? If you are with a newer version than 5.3.1, please send block.svg to our support email address.
