Normal Topic VB.Net support (Read 2696 times)
gau_sha
VB.Net support
Oct 27th, 2010 at 10:19am
Hi All,
Is it possible to use this reporting tool with VB.net code as the project we are working on is purely on VB.Net.
Re: VB.Net support
Reply #1 - Oct 27th, 2010 at 11:10am
If you are referring to MindFusion.Reporting for WinForms, it is possible to use it in both C# and VB.NET projects. The code generated from the built-in visual designer should match the language of the target project.
If you are referring to MindFusion.Reporting for WPF/Silverlight, there are no language restrictions either.
Let me know if you have further questions.
