Normal Topic DiagramNodeCollection (Read 1501 times)
Amosius
Nov 10th, 2010 at 4:05pm
i am confused with my DiagramNodeCollection.
I have a collection with 5 nodes and i insert one more:
int i = 2;
ShapeNode node = new ShapeNode();
myDiagram.Nodes.Insert(i, node);
Now i get the position of my node:
int pos = myDiagram.Nodes.IndexOf(node);
pos is not 2, it is 5. My Node is in the last position, instead of position 2.
Is there a problem with DiagramNodeCollection, or do I have a problem with my head Smiley
Re: DiagramNodeCollection
Reply #1 - Nov 10th, 2010 at 4:17pm
That would work if you were using a standalone DiagramNodeCollection, but the diagram's instance is a bit strange. Its Insert and Add methods raise an event that passes through the undo manager and adds the node both to diagram.Items and diagram.Nodes, but your index is lost in the process. We can try to add support for insertion too, but don't dare touching that code just now before the release Smiley
Amosius
Reply #2 - Nov 10th, 2010 at 8:04pm
Hi Stoyan,
thx for this quick hint.
I created a "workaround". It's fine.
