Normal Topic Custom Drawing (Read 3431 times)
frankinstien
Custom Drawing
Nov 10th, 2010 at 7:51pm
I'm trying to draw SVG images on a shape and created a SVGShape class that inherits from the Shape class. When I create the .NET Graphics object from the hdc of the node's IGraphics the svg image won't show. If I create the graphics object from a bitmap and store it in the node's Image I can get a figure, but the image gets stretched or compacted depending on the size of the bitmap and the shape node. Below is the code I'm using:
void Diagram_DrawNode(object sender, MindFusion.Diagramming.DrawNodeEventArgs e)
SVGShape aNode = (SVGShape)e.Node;
aNode.ShapeNodeHdc = e.Graphics.GetHdc();
aNode.Load(@"E:\Symbols\Piping\Process_These_Files\OneSymbol.svg");
I did look at the custom draw sample which uses the MindFusion IGraphics to draw. The Shape class I created uses a .NET Graphics object, which is why I created the .NET Graphics from the IGraphics hdc.
Any help or examples that draw onto a node using the .NET Graphics would be appreciated.
Re: Custom Drawing
Reply #1 - Nov 10th, 2010 at 8:29pm
Is there any reason not to use the SvgNode type that comes with the control? In any case you can get the GDI+ Graphics object like this:
MindFusion.Drawing.GdiGraphics graphicsWrapper = (MindFusion.Drawing.GdiGraphics)e.Graphics;
System.Drawing.Graphics gdiGraphics = graphicsWrapper.Graphics;
frankinstien
Re: Custom Drawing
Reply #2 - Nov 11th, 2010 at 4:12am
Thanks for responding.
I was able to get the .NET Graphics from the node IGraphics as you demonstrated. The final rasterimage is drawn but won't show up in the shapenode. Is there another trick to this?
Also I wasn't aware of a SVGNode only the SVGGraphics interface which isn't what I need. I'm using an SVG picturebox hack and replacing it with a Shape node. The control reads the svg xml directly.
Re: Custom Drawing
Reply #3 - Nov 11th, 2010 at 7:45am
Do you need to copy the content rendered in some svg picturebox control and display it as bitmap in the ShapeNode? If it provides a method that returns a bitmap, you could call e.Graphics.DrawImage to render it inside the node, or just assign it to the Image property. But please try using the SvgNode class, e.g.
SvgContent content = new SvgContent();
content.Parse(@"E:\Symbols\Piping\Process_These_Files\OneSymbol.svg");
diagram.Factory.CreateSvgNode(bounds, content);
Or if you need to render several SVG images in the same node, you can do that by calling the SvgContent.Draw(IGraphics, RectangleF) method from the DrawNode handler.
frankinstien
Re: Custom Drawing
Reply #4 - Nov 15th, 2010 at 5:43pm
stoyo,
Thanks for all your help. I did upgrade and now have the svg capability. But now I'm having a problem trying to load the svg images to a shapelistbox. Any suggestions?
Thanks.
Re: Custom Drawing
Reply #5 - Nov 15th, 2010 at 9:09pm
At this time ShapeListBox can display only Shape objects. If you need a list of arbitrary nodes, check the custom-drawn listview implementation from the Flowcharter example.
