Normal Topic Flowchart.NET on Linux w/ Mono (Read 2987 times)
RobMcCready
Nov 11th, 2010 at 5:17pm
Flowchart.NET looks like the perfect fit for an upcoming project, but I need to know one thing:
Will it run on Linux w/ Mono?
We need to be able to run cross-platform.
Rob
Re: Flowchart.NET on Linux w/ Mono
Reply #1 - Nov 11th, 2010 at 5:28pm
It did not work well last time we tried a few years ago. We'll check it again tomorrow.
Reply #2 - Nov 12th, 2010 at 1:59pm
It does not work well yet; the sample we tried printed "not implemented" warnings in the console about the Graphics.TransformPoints method, which the control uses a lot. We also tried our Silverlight control under Moonlight - it seemed to work fine at a first glance. If you have not decided on the platform yet, you might also check our Java/Swing component.
RobMcCready
Reply #3 - Nov 12th, 2010 at 4:35pm
Hi Stoyo,
Thanks for trying it out! Is this on the latest Mono 2.8?
Cheers,
Rob
Reply #4 - Nov 12th, 2010 at 6:39pm
Hi Rob,
We tried it on the version included with the latest Suse Linux, I think Mono v2.6.4. We can check it on 2.8 next week.
Cheers,
Reply #5 - Nov 16th, 2010 at 12:41pm
Hi Rob,
Mono 2.8 does not work either. We managed to get most of it working with a custom TransformPoints implementation, though there are still some glitches when scrolling the diagram; we can try to find a work-around if you are still interested in using Mono.
RobMcCready
Reply #6 - Nov 16th, 2010 at 4:33pm
Hy Stoyan,
Thanks very much for checking on that. We'll consider our options here, and I'll let you know what we decide to do.
Cheers,
Rob
