Normal Topic Delete of Nodes and Inplaceedit Text (Read 2228 times)
Amosius
Nov 15th, 2010 at 10:23am
since a couple of days:
I am not able to delete Nodes with the delete key.
I can't use delete key in an inplaceedit mode. In a Textbox it is still working.
When i enter an inplaceedit mode the cursor was in the text, now i have to focus the inplacetextarea.
Have you ever had this problem? I deleted a lot of properties of the diagram and the code i made in the last days. But this behavior is still the same.
Hope for any hint.
Amosius
Re: Delete of Nodes and Inplaceedit Text
Reply #1 - Nov 15th, 2010 at 11:29am
Are you now using the V2.5 beta?
Amosius
Reply #2 - Nov 16th, 2010 at 9:32am
No, i have still 2.4.
Reply #3 - Nov 16th, 2010 at 9:59am
Have you got Focusable="False" set for the containing ScrollViewer or Ruler control? It might be stealing the keyboard focus otherwise.
Amosius
Reply #4 - Nov 16th, 2010 at 1:15pm
Uhhhh fantastic, that was it Smiley I appreciate your hints.
