Normal Topic SVG Rendering Problem (Read 3829 times)
frankinstien
Nov 19th, 2010 at 6:16pm
Below is a link to a svg file that MindFusion Content doesn't like.
http://atlasdynamics.com/3-Conductor%20Handset.svg
The file will render in browsers and in SharpVectors' SVGPictureBox.
Re: SVG Rendering Problem
Reply #1 - Nov 22nd, 2010 at 8:41am
It should work with this new build of the v5.5 beta:
https://mindfusion.eu/_beta/fcnet55.zip
Reply #3 - Nov 22nd, 2010 at 6:30pm
In what application have you created these files? None of the browsers I tried could render them... Regarding the 3-conductor one - it appears the same as in Opera and Chrome with the new version (Firefox could not render it either), so make sure your reference path points correctly to the latest build and the "use specific version" property is not enabled for the flowchart.net assemblies. Here is how it appears in our test app and in Opera:
frankinstien
Reply #4 - Nov 22nd, 2010 at 10:52pm
The files were originally created in Visio. I did normalize the transforms which cause some problems in some of the images. But I then tried the template svg from which all the files of these particular symbols are from. The Mindfusion rendering isn't any where near that of Opera or SharpVectors. Below is a screen shot:
http://www.atlasdynamics.com/AllSymbols_MF.jpg
This is the file:
http://www.atlasdynamics.com/Accoustic%20Devices_2.svg
Reply #5 - Nov 25th, 2010 at 5:13pm
This file contains nested <svg> elements and that's not supported by SvgNode at this time. Our developers we'll check if they can implement that for the 5.5 release.
Reply #6 - Nov 26th, 2010 at 11:34am
This build should render nested <svg> fragments correctly:
frankinstien
Reply #7 - Dec 20th, 2010 at 9:05pm
How soon will 5.5 be available as a release?
Reply #8 - Dec 21st, 2010 at 8:25am
We have released it a couple of weeks ago.
