Normal Topic SVG expport problem (Read 4180 times)
Dexter
SVG expport problem
Nov 23rd, 2010 at 7:44am
Hi there!
I have exported a diagram to SVG and found the a text that is drawn by custom code is moved in svg. Find attached an with the result (in Firefox). .
The right is displayed in the diagram and the left is how it is viewed in Firefox.
The rectangle and text are drawn at the same location the the size of the rectangle is the size of the text given by the measurestring method.
Does anybody have any idea why this is happening?
Best regards,
Dexter
Re: SVG expport problem
Reply #1 - Nov 23rd, 2010 at 3:02pm
Hi, Are you using the DrawString(RectangleF) overload?
Dexter
Reply #2 - Nov 24th, 2010 at 7:14am
Hi Stoyo!
Here is the code that draws the text and the rectangle
Pen pen = base.HeadPen.CreateGdiPen();
Brush brush = new SolidBrush(this.TextColor);
string text2Draw = "pm"
SizeF textSize = graphics.MeasureString(text2Draw, this.Font);
graphics.DrawRectangle(pen, stringLocation.X, stringLocation.Y, textSize.Width, textSize.Height);
graphics.DrawString(text2Draw, this.Font, brush, stringLocation);
pen.Dispose();
brush.Dispose();
The stringLocation is calculated based on some particular parameters.
The graphics is the parameter from the override Draw method
Dexter
Reply #3 - Nov 24th, 2010 at 7:35am
Hi Dexter,
Is stringLocation a PointF or RectangleF?
Dexter
Reply #4 - Nov 24th, 2010 at 10:21am
Hi Stoyo,
stringLocation is a PointF structure.
Dexter
Reply #5 - Nov 25th, 2010 at 7:58am
This version should add a smaller offset at front of the string:
https://mindfusion.eu/_beta/fcnet55.zip
Dexter
Reply #6 - Jan 26th, 2011 at 3:05pm
Hi Stoyo!
I just read that you are planing a new release of version v5.6. Does this problem, or should I better say, the solution you provided here is solved there
Regards
Dexter
Reply #7 - Jan 26th, 2011 at 3:25pm
Hi Dexter,
That fix should be included in v5.5, which we released in December last year.
Dexter
Reply #8 - Jan 26th, 2011 at 3:31pm
I see!
On the download page for the flowchart.net there is version v5.4 http://mindfusion.eu/download-net.html
Probably there is spelling mistake.
Best regards,
Dexter
