Hot Topic (More than 10 Replies) Add new appointment (Read 7896 times)
TataTomy
Don't worry - be :)
Add new appointment
Nov 23rd, 2010 at 3:34pm
i found a way how to create new appointment from program:
Private Sub FormPlan_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
Dim i As Integer = 0
For i = 0 To 25
Dim aLocation As MindFusion.Scheduling.Location = New MindFusion.Scheduling.Location
aLocation.Id = "myLoc" & i
aLocation.Name = "Location " & Str(i)
Me.Calendar1.Locations.Add(aLocation)
Next
Calendar1.InteractiveItemType = GetType(MyApp)
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim varLoc As Integer
varLoc = Val(TextBox3.Text)
Dim app As New Appointment()
app.HeaderText = "TataTomy"
app.DescriptionText = "Comment"
app.StartTime = New DateTime(2010, 11, 22, 14, 0, 0)
app.EndTime = New DateTime(2010, 11, 24, 10, 0, 0)
app.Location = Calendar1.Locations(varLoc)
Calendar1.Schedule.Items.Add(app)
End Sub
but I still did not found a way how to create new appointment with same elements by drawing at calendar with mouse...
my calendar has currentview = resourceview
can you help me?
Re: Add new appointment
Reply #1 - Nov 23rd, 2010 at 4:12pm
Appointments are created (drawn) interactively by first selecting a time interval with the mouse and then typing. The newly created appointment spans the selected time interval. Its HeaderText is set to the text entered by the user in the text box. Its DescriptionText however needs to be set through other means. For example, you can handle the ItemCreated event and display a custom form or implement a custom item editor.
Appointments can also be created interactively through dragging. To enable this functionality, set Calendar.EnableDragCreate to true.
Let me know if this helps.
TataTomy
Don't worry - be :)
Reply #2 - Nov 23rd, 2010 at 4:44pm
God bless you Meppy! The secret was in "set Calendar.EnableDragCreate to true"
TataTomy
Don't worry - be :)
Reply #3 - Nov 23rd, 2010 at 5:07pm
One more question: how to move appointment over calendar verticaly (changing locations) with mouse (drag & drop)?
Reply #4 - Nov 24th, 2010 at 6:58am
You need to hold down the modifier key specified by ItemChangeReferenceKey (by default it's ALT) before starting to moving the item.
Let me know if it helps.
TataTomy
Don't worry - be :)
Reply #5 - Nov 24th, 2010 at 8:20am
It works, of course... Thank you very much...
Actualy - there is a lot possibilities in all events, methods, classes...
TataTomy
Don't worry - be :)
Reply #6 - Nov 24th, 2010 at 9:11am
Next question: how can I select and control an appointment form program... I need to change item.style.fillcolor by click one of several buttons (ex. ButtonRed, ButtonGreen, ButtonYellow)...
As a first step I get item.id with
Private Sub Calendar1_ItemClick(ByVal sender As Object, ByVal e As MindFusion.Scheduling.WinForms.ItemMouseEventArgs) Handles Calendar1.ItemClick
       If e.Button = Windows.Forms.MouseButtons.Left Then
           TextBox3.Text = e.Item.Id
       End If
    End Sub
but I do not know how to select an item (Item.Id is i TextBox3.Text) and change color
Have you got something like:
Calendar1.Item.Id(Textbox3.Text).FillColor = Color.Red
I belive you have somethnig good...
Tomy
Reply #7 - Nov 24th, 2010 at 12:18pm
An item can be identified by its Id by passing the id as an index to the Schedule.Items collection:
calendar.Schedule.Items(itemId)
Items can be selected programmatically by adding them to the Calendar.ItemSelection object:
calendar.ItemSelection.Add(item)
The background color of the items in Resource view is specified through the HeaderBrush property of the corresponding item style. For example:
item.Style.HeaderBrush = New MindFusion.Drawing.SolidBrush(Color.Red)
item.SelectedStyle.HeaderBrush = New MindFusion.Drawing.SolidBrush(Color.Red)
TataTomy
Don't worry - be :)
Reply #8 - Nov 25th, 2010 at 4:39am
This is exactly what I need... Thank you very, very much...
Tomy
TataTomy
Don't worry - be :)
Reply #9 - Nov 29th, 2010 at 4:18pm
I have problem with:
System.NullReferenceException was unhandled
  Message="Object reference not set to an instance of an object."
  Source="MindFusion.Scheduling"
  StackTrace:
      at MindFusion.Scheduling.Item.GetHashCode()
      at MindFusion.Scheduling.WinForms.x30788aa4e2c76c13.GetHashCode(Item a)
      at System.Collections.Generic.Dictionary`2.FindEntry(TKey key)
      at System.Collections.Generic.Dictionary`2.ContainsKey(TKey key)
      at MindFusion.Scheduling.WinForms.Calendar.xb33e7b23311adcf5(Item xccb63ca5f63dc470)
      at MindFusion.Scheduling.WinForms.Calendar.x4342ef569299dc36(ICollection xf8b54ce7724a27f2)
      at MindFusion.Scheduling.WinForms.Calendar.OnMouseMove(MouseEventArgs e).....
This problem occurs when I try to create new item - appointment with mouse on calendar AFTER I loaded old appointments from database...
there is sample code I used...
by _Load:
                       app.Id = DataGridView_Rezervacije.Rows(iBroj).Cells(0).Value
                       app.HeaderText = DataGridView_Rezervacije.Rows(iBroj).Cells(0).Value & " / Kupac"
                       app.Location = Calendar_Glavni.Locations(jBroj)
                       app.StartTime = New DateTime(Int(Format(varDolazak, "yyyy")), _
                                                    Int(Format(varDolazak, "MM")), _
                                                    Int(Format(varDolazak, "dd")), 14, 0, 0)
                       app.EndTime = New DateTime(Int(Format(varOdlazak, "yyyy")), _
                                                    Int(Format(varOdlazak, "MM")), _
                                                    Int(Format(varOdlazak, "dd")), 10, 0, 0)
                       Calendar_Glavni.Schedule.Items.Add(app)
                       Calendar_Glavni.ItemSelection.Clear()
                       Calendar_Glavni.ItemSelection.Add(app)
by _ItemCreated:
e.Item.Style.FillColor = Color.Yellow
       e.Item.HeaderText = "New"
       e.Item.DescriptionText = "Tata Tomy / " & FormatDateTime(Now, DateFormat.GeneralDate)
       e.Item.StartTime = New DateTime(Int(Format(e.Item.StartTime, "yyyy")), _
                                       Int(Format(e.Item.StartTime, "MM")), _
                                       Int(Format(e.Item.StartTime, "dd")), _
                                       14, 0, 0)
       e.Item.EndTime = New DateTime(Int(Format(e.Item.EndTime, "yyyy")), _
                                       Int(Format(e.Item.EndTime, "MM")), _
                                       Int(Format(e.Item.EndTime, "dd")), _
                                       10, 0, 0)
Can you help me?
Tomy
Reply #10 - Nov 30th, 2010 at 10:14am
Can you check if the Item.Id is Nothing after the following call:
Item.Id cannot be Nothing. If it is, assign a value to it but make sure that it is unique within this schedule.
TataTomy
Don't worry - be :)
Reply #11 - Nov 30th, 2010 at 11:25am
God bless you, Meppy! It works...
Thanks again...
Tomy
Reply #12 - Nov 30th, 2010 at 12:24pm
God bless you too, Tomy!
