Normal Topic Right click support and Cursors (Read 3160 times)
rajesh_patil74
Dec 2nd, 2010 at 10:12am
Hi Stoyo
Is there any plan to provide different cursors when mouse is moved on adjusment handles ?
Also , is it possible to provide a right click check support which detects the node/link on which right click is pressed and that info is passed to the "OnContextClick" event ?
As of now, the right click is implemented in my custom code, where i the node is found using my own code. I guess this should be in-built in the libarary.
-Rajesh
Re: Right click support and Cursors
Reply #1 - Dec 2nd, 2010 at 4:15pm
Hi Rajesh,
Silverlight does not allow using custom cursors and provides only a handful of predefined ones, so we haven't added cursor properties for adjustment handles. Yet you could use the OverrideCursor property or override the BehaviorBase.SetMouseCursor method to return a different cursor from the Cursors class members. Now I see Silverlight 4 adds SizeNESW and SizeNWSE members - we will set them as default for the corner points in the next version.
In Silverlight 4 you could add a Diagram.MouseRightButtonDown handler and call GetItemAt to detect the item under the mouse pointer.
rajesh_patil74
Reply #2 - Mar 21st, 2011 at 8:55am
Hi Stoyo
In latest version did SizeNESW and SizeNWSE cursors used by default ?
-Rajesh
Reply #3 - Mar 21st, 2011 at 12:46pm
It seems we have omitted adding them. We'll try to later this week.
Reply #4 - Mar 22nd, 2011 at 8:11am
Hi Rajesh,
We have added the diagonal resize cursors, please check the PM page.
